1934 5 window garnish moldings
uncle buck
Are there differences between the window garnish mouldings on a 33 vs 34 5 window coupe? How about 5w vs 4 door? I know the back edge of the window opening is different with the filler strip on the back edge of the 34 door.
Pictures would be great.
Thanks, Dave
The back window garnish is the same 1933 and 1934, 3 Window and 5 Window.
The quarter window garnish are the same 1933 and 1934, 5 Window only.
The door garnish moldings are 5 window only.
1933 standard and deluxe.
1933 standard and deluxe with "finger pull" (very late only).
1934 door garnish moldings are about 1" shorter than 1933 to accommodate the glass slide feature. 1934 standard moldings are straight on the bottom and very similar to 1933, 1934 Deluxe molding have the shaped bottom. Some early 1934's may have had the "finger pull" feature.
I still can make (for another month) fiberglass 1933 moldings.
Five window coupe and four door sedan doors are NOT the same. The only similarity is from the belt line down and I'm not really sure about that either. The door tops are completely different as is the hinge location. Such differences also include the garnish moldings.
