1933-34 Ford Frame
34cpe5w
IL, MN, WI, IN, IA
Looking for a 1933 or 1934 Ford frame. Want to use it to put my body on when I paint it. So it does not have to have good crossmembers, if it has some rustout in the rails, that is fine. Does need to be straight and not a twisted mess.
As long as the frame is from the front of the cowl to behind where the rear crossmember is, that is what I need.
PM with what you have, where you are located and what you are asking for the frame.
Thank you, Matt
