- City
- Gilroy
- State
- CA
- Price
- $245.00
This '32 transmission case has a '32 top rebuilt with NOS forks and shift rails. This case is stamped with Engine Number 18-34352, has been bead blasted inside and outside with Gyptol enamel sealer on the inside and metal protectant on the outside. A '32 type rear bearing retainer is included as well as the rear ring plate which can be hard to find. The shifter is a '35 type which was offered as a replacement by Ford. Thank you, Paul
