Thinking of going back to mechanical brakes on my '32, what have you got sitting around that you don't need? Drums, baking plates, so forth? PM please, thanks, Gerald
Just a reminder that there are two styles of backing plates depending on when the car was built. The good news is that you can use either one if you are not trying to make sure your car is correct for when it was built. I am sure it is covered in "The 1932 Ford Book". You might as well hold out for the correct ones since they will probably cost the same.
