1932 hotrod chassis
lbtraderdave
long beach
ca
Price
in the add
i pulled the body off and wanted to go with a roadster body..but found something else...so here it goes ...1932 ford running chassis ...radiator. new hoses...ford 8 in rear end split wish bones drum brakes ..brand new driveline complete brand new clutch setup,freshed up 283 v8 ..new oilpump,altanator,fuelpump,all new major tuneup,camel hump heads,headers,chrome valve covers,big carb,lots of chrome on the motor,motor is painted black,3 speed trans,up front looks like 4 in drop axel 40s ford brakes,and spindels, split wishbones all the brakes lines are hooked up,32 steering box, 32 cloum with key,new coil,new regulator,water pump, i beefed up the motor mounts,and trans mounts, i have ALOT of money in this project,..the chassis needs a fuel tank,pedal assembely,to be a runner,also have the wireing ran with a fuse pannel...this would be perfect for some one who wants a genuine 32 ford chassis all the work is done u could buy a brookville 32 body body ,gas tank, and pedal assembly,and you could be driving before the summer is over..the frame is reg. in califorina as a 32 pick up...i hate to get rid of this but found something else......asking 13,700...gets you this complete package.
