1932 coupe rear spring
CraigB
Looking for a picture of a 1932 coupe rear spring. Have a rear end out of a sedan? with 11 leaves that I will be using to build a coupe. Need to know which two leaves to pull.
Pretty sure #10 is gone as it is thinner than the rest, # 11 is bevelled so it stays, but which of the rest??
Thanks
If you want to replicate original, go to the '32 parts book--the late one is readily available from the parts dealers--and go through the spring leaves one by one, cataloging what leaves go in each type of spring...obviously, you'd start with the sedan one on the assumption that is correct and complete. You will likely find that there are different leaves within the pack that aren't used in both quite aside from the different numbers...leaves vary in thickness as well as length. If you are lucky, everything might match up using leaves that are in the sedan pack. The list of all the leaves will require charting and some aspirin to figure out.
If you are just seeking a softer spring and are not worried over whether the third leaf is the correct one, one factor is not to leave big differences in the lengths of the areas not covered by the next leaf above...if you discard such that there is a long unsupported area at a level in comparison to the others, that becomes a sort of hinge point in the spring and it will flex more at that point rather than compressing equally over its whole length.
I have a fairly stock 32 5W and it rides great. Henry knew what he was doing. I did take it apart and cleaned the spring. I greased it and reinstalled with stock style shackles. I would not change a thing.
Thanks for input. The #10 was a different gauge, which it shouldn't be for a coupe. The rest are fairly even which is why I wasn't sure which to pull.
Andy can you get any kind of an picture of your rear spring??
6 leaves?? a thought.
Here's pic of the spring in my 5 window. I believe it is original but can't be sure. 11 leaves total.
Go to the green Ford bible and the leaf assemblies are listed for each model
Also Eaton Springs in detroit and make a repo to orginal specs (they have a website)
Definitely 9 leaves. But my Ford book doesn't show a picture of the various springs.
What book has the pictures??
Thanks, Craig
Does anyone have a shot of a 32 coupe rear spring, 9 leaves??
Even if the shot doesn't show all the leaves it would be helpful.
Thanks, Craig
Her a couple crappy cell phone shots but maybe they will help... let em know if you need any particular shots.. mine is still intact
Looks like you have a couple of cracked springs there. Hopefully it is just some goop on the springs.
