You need to know if you are looking for an early one or a late one. I don't believe you can put the early one on a late car due to interference. There is a guy selling reproduction early ones on ebay right now. He says they will only fit late cars but I believe he is mistaken. The early one takes the dog leg sun visor brackets. You will see the dog leg indent in his header tin photo. You will also find the dog leg early sunvisor brackets for 32 3W on ebay right now. Brookville makes a 32 3 window header tin that has no visor mounts and is just flat in that area where the visor mounting indents would be. By the way, the late year Deuce 3w header tin has rectangular shaped indents for mounting the late visors. Those late visors use the same brackets as 1933 and 1934 (standard) --not deluxe sunvisors. You can also buy those late brackets as reproduction parts. So, if you have a late car, that Brookville header might work for you. Real ones are darned tough to find in early or late. Best of luck to you. Sir Duce
