1929modela
- City
- Red Lodge
- State
- mt
- Price
- $4500
Hey guys, I have a 1929 Ford model a tudor sedan. I am the third owner and have changed directions with my intentions. This car is WAY to nice for me to cut up. It is a true barn find. It has been stored on blocks, covered since 1972. I was told by the second owner that he rebuilt the motor years ago. It supposedly was driven to where I picked it up. I believe this to be true. The old girl is all origional except for the headlight bulbs. As you know, you cant see with the origional model a bulbs and these were upgraded with a sealed beam by the previous owner. The doors and hood open and close nicely, latches work etc. All the glass is there and move up and down with ease. I took out the rotted wood floor in the front but the rear wood is still there. Top bows are there and so is the chicken wire top. Drivers seat is springs and frame, passenger seat has cover and foam still on it. Both still fold as origional. Back seat is seat frame and springs. Under the back seat is an old tire wrench, tube repair kit and jack. The transmission shifter moves through the gears as should. steering feels tight and clutch and gas pedal are functional. The timing advance/retard lever and throttle lever on the column move and work as they should. The cowell gas tank was flushed with MINIMAL crud coming out and pressure tested good. I BREIFLY STARTED AND RAN THE OLD GIRL SO I KNOW SHE WILL RUN WITH SOME TLC. the oogah! horn works as well. The body is exceptional for a model a. It is VERY straight and NOT beat up. The rust is minimal and consists of a small ammount in either side of the lower cowell and behind drivers and passenger rear fender. This is a very small amount of rust and patch panels are readily available. It would not take much to get this old girl on the road. There are no tires on it. The four origional steel wheels roll it around my shop. I will take photos of anything you want if you provide me with an e-mail. I will take it to Billings Montana to a shipper of your choice. My phone number is 406-425-0428. I work odd hours so leave a message if i dont answer. I WILL call you back.
For some reason i cant pics to load. Ill send them to you and try again to upload later.
Thanks
Thanks
