1928 Motor
TK in LA
La Verne
Ca
Price
$1,000
SOLD !
For your consideration is this 1928 Model A Ford motor. It will fit all years if you change intake manifold and water outlet for 1930 or '31. The Serial number on block designates it as an August of '28 build. *1364XX . Not sure if the number is in the system or not. I've disassembled and cleaned everything. Original standard bore with new wrist pin bushings with later style pistons. Babbitt in rods and block are OK?. Cam (5 bearing) and crank gears are good, water pump was cleaned and repacked with original style lead packing. This includes the starter and working generator. Carburetor was cleaned and adjusted. I have only run the motor on my test stand and there are no guarantees as to future reliability or performance. What you see is what you get. Doesn't overheat. Slight rear main drip. Includes everything in pictures except any parts for my test setup. $1000.00 First come, first serve. Shipping not available but can deliver locally for a small fee. The motor is located in La Verne, Ca.. Come hear it run. No negative comments needed!
