Wanted: I need one hinge similar to the one pictured. The only real requirement is two rolls for the pin. A longer or shorter flat will also work, I can cut or weld as needed. Thanks Gary in MN.
I have one with a three inch flat and of course the two rolls for the hinge pin. In the middle of the flat is the letter R. $12.50 postpaid anywhere in USA
