1927 Model T Cab and frame value
Ford48truck
New member
How much this is worth ?
I just trying to gauge the value before buying
Cab with doors ( not in the picture) everything is pretty solid
No trunk door, There is a frame (but not in the pic) with no axle or nothing..
The 26-27 coupe body, maybe a few hundred if really solid. Theres A LOT missing and will be a very time consuming project all in itself just to put that back together. If the frame is a 26-27 and complete, i.e. body mounts, brake lever and cross shaft and battery box, maybe $100. If its a late 26 through 27 frame there should be a serial number stamped on the top of the frame rail just about inside the passenger door. Mite need some sandpaper to pick it out. DO NOT over sand it! ws
Thanks alot for the help !
Ill have to pay more than 200 $ around here ...not to much left around here,
I live on the east coast , ocean is right beside so everything rust more.
It was brought from out west.
Ill check for that serial number...i didnt know exactly where it was
