1927 Coupe Firewall
Flathead Dave
I need to change out the firewall on my 1927 Coupe. Does anyone know which firewall would fit instead of using a stock 1927 Coupe firewall? Which after market or 1930's firewall would fit my Coupe?
i have heard of people taking a left hand drive firewall & turning it around & using it in a right hand drive with the extra space for after market heads, not sure it that will for for you.
A 26 will fit. What are you trying to do? If its a larger engine and ****** situation a custom firewall may be needed. There were not many interchangeable parts back then. Check the H.A.M.B. and other rod sites. Good luck.
