- City
- OMAHA
- State
- NE
- Price
- $1200.00
1926 real steel roadster pickup.
Model A frame
51 Merc flathead, Offy heads, Offy 2x intake, 94's,
40 Ford rims with new never used Firestone 16's
Wilson welding finned aluminum backing plates on all four corners with buick 45 finned drums on 39 spindles.
40 Ford banjo rear 3.78 gears, Model A rear spring.
4 inch Dropped and drilled front axle, F100 shock mounts with shocks.
Split front wishbone drilled
39 Ford transmission with 32 crossmember, 32 pedals for hydraulics, no guts in transmission. Healey Sprite seats= look like bombers only better
Project is mostly assembled or mocked up and will need finalized. Engine ran well no smoke before removing heads and intake, heads are just sitting in place as is the intake and carbs.
extra Model A frame
13 reproduction 32 Av8 crossmembers: 13 x $400.00 = $5200.00
three bare Flathead blocks
top shift transmission cases, three or four double detent top shift asslemblies with new shift kits, not assembled.
complete set of 39 wide five brakes, backing plates, spindles
extra banjo rear end, four wide five rims with tires
extra 26 Roadster pickup body and box
AND MORE STUFF THAT IS IN BOXES.
I am in Afghanistan and will be for a few years and wont have time to work on this. There is a lot of high quality traditional parts here that make up essentially two cars. I do not have pictures at this time but if you would like to see, email me and I will arrange it. PRICE IS FIRM. Help a HAMBER out, I am almost giving this stuff away. gijoe@mymaza.com
TIM ELDER
RAREBIKE
Model A frame
extra Model A frame
TIM ELDER
RAREBIKE
