Itchy-Pit
Okay folks,
Car has been running okay on BATT and COIL. BUT with the connection at the Hogshead being loose - depending on if I turned the wire right or left it would run on COIL or sometimes would not. So I carefully disconnected the oil line and adaptor, the wire nut, then both the set nuts leaving just the threaded post. Then I realized the threaded post could be removed so I removed it then the large nut. The threaded post resembles a spring loaded dart tip which looks to make contact with the Mag top - about the size of a Nickel. I tried putting a thin washer on the spring/threaded hold it in place and now nothing.
What is the design of the spring loaded post for? Can it be tightened too tight or loose? Can they go bad? I even added a wire to rule out a bad terminal to Coil box wire. Runs fine on battery. But I am stumped now.
HELP!
Thanks! Dennis
HELP!
Thanks! Dennis
