Go to TCP Global website in S>. CA. Bc /cc is base coat / clear coat. TCP has Model A Formulas, but as stated , very little paint in an aerosol can, most content is propellant. Depending on colors, a few quarts may be needed with the proper thinners, catalysts, etc. The 2K single stage formulas are fine for small areas or touch up.TCP sells lacquer ( for non VOC states or locations) which dries fast but needs special prep as stated. Base / clears/ single stage require dust free areas for a good result.
As we know, factory paint was lacquer bodies, dipped enamel for fenders ,splash aprons, wheels, etc.
