I’m in the process of mocking up my pedal assembly (1940) to my C59A. I have the engine attached to the trans and I need to know what the correct orientation for the flange on the shaft for the clutch forks. I don’t have the clutch/pressure plate/throw-out bearing installed. I’ve modded the corresponding shaft from the pedal assembly by shortening it. So, before proceeding further, I need to understand how to index the mating flange on the shaft.
