Have you tried to lower you car like this?
Ok....the pics look like they're from the '60s so, old skool. With technology advances over the last 60 years I'd say Aerostar coils would be the way to go over whatever that was, and will drop the car the same amount. Cheap, simple, safe and easy to install. Couldn't be happier with the amount of lowering and ride quality from the Aerostar coils on my '54! Just my $.02.
I agree seems a little wonky to do that. I have the aerostat springs (2" drop) and granada spindles with the spacer from drop em. (2" + drop). So I should be 5" lower in front but it doesn't seem that low to me. My avatar is a current pic but I can't load it here I do have big tires which keep the car higher off the ground. I'm thinking of doing the spring perch spacer I've read about. Any feedback on that?
